Stuck with JB with USB issue inside warrantee !!
Dannyrobson
Hi,
My iphone 5 has started to play up, windows will not recognise it atall.
Every now and then it will work the way it should. The big problem I have is I can't upgrade my firmware, is there a way of switching the wireless software update on?? If not does anyone else have any ideas of how I can take the jailbreak away ??
Thanks in advance !!
Reinstall your USB drivers. If not reinstall both your iTunes and USB driver
Hi,
You can't do an OTA iOS upgrade with a jailbroken device, it has to be done while connected to iTunes on your computer. One of the features of the evasi0n jailbreak is that it disables the ability to update OTA.
