Somebody please help
camenglish
im sorry if this is in the wrong place but i have an iphone 6 never been jailbroken or anything and i went to install ios 9 on the phone and it would download just not install so i tried this morning on itunes and it got half way done and said it could not be completed and now my phone can only be connected to itunes and when it is my only options are update or restore and update. ive done both and neither work and i cant use my phone. somebody please help im in a hurry so please excuse my grammar
Did you read the instructions in the link I provided? To put your iPhone into recovery mode you don't connect it as usual. You'll need to follow the description exactly, or else you'll just try to restore it again, which will result in the popups you're getting.
yes i did. The second pic i showed is what happens
when i run tu it says that it cant find java and i just updated it
Try removing Java and reinstalling the latest version.
Also make sure computer and iTunes are up to date.
I hope it's fixed If u have a problem and cannot fix it go to apple
I updated mine ota
