Brightslide is Cydia Tweak which allows you to set an Activator action to pop open a settings and shortcuts tab. The tab will show up right under your status bar with Brightness controls showing up first. You can swipe to the left and you'll then be able to adjust your Volume using a slider. Swiping to the right brings up WiFi, Bluetooth, Airplane Mode, and Flashlight toggles on one side. On the other side we can choose three application shortcuts in the settings. Brightslide can be found for FREE under the Big Boss Repo in the Cydia Store.
