SE Battery Issue?
SE Battery Issue?
Russtopher
Active Member
I really like my SE and want to keep it. However, it has recently begun to act funky. The battery charge will go from 100% down to VERY low in a matter of minutes. Sometimes while it is on the charger. But, when I shut the phone off, then back on, it will jump back up to nearly fully charged. The battery health beta lists the battery health at 97%. When an Apple tech did a remote test of the battery, they said that the battery itself is fine and healthy.
Anyone else ever have this issue? I would rather not upgrade to the I phone 8.
Thanks
My 5S does some wonky discharging but otherwise nothing like what you have. Two people I work with have had issues exactly like you describe, one on an 8 Plus, the other on a 7. They ended up sending both in to Apple and have replacement devices now.
Thanks. T-Mobile is replacing it for free, with Apple refurbished model. Do refurbished models come with a healthy battery?
Refurbished iPhones come with a new battery and likely a new case and screen if necessary. They look and work just like new.
Thanks. Good to know. I really did not want to go to the I Phone 8.
Thanks
Scifan57
I deleted al info and settings on the phone, then reset everything from a very recent I Coud back-up. Do you think that may resolve any software issue it may have?
Thanks
Scifan57
Thanks
If the problem was software related it could help. If there is a hardware issue restoring from a backup won't help.
You are correct. I tried that. Did not work.
Thanks
A full diagnostic at an Apple Store Genius Bar would determine the cause of your problem. The appointments are free and if a repair is needed you’ll be quoted the out of warranty repair cost if your warranty has expired.
T-Mobile has already ordered me a refurbished, replacement SE. can I assume that it will come with a new battery?
Thanks
Thanks
Like I said earlier, all refurbished iPhones come with a brand new battery. Let us know how your replacement iPhone works.
Will do.
Thanks
