try a hard reset,hold down your sleep/wake button and home button at the same time until the apple appears,that clears most glitches.My status bar just disappeared from my lock and home screen. Any ideas?
Poisonivy said:try a hard reset,hold down your sleep/wake button and home button at the same time until the apple appears,that clears most glitches.
IOSMonkee said:I tried that thanks for the response, but I figured out what the problem was. Somehow I had a thing called no status downloaded from cydia ..
zig9449 said:Lol.
You really need to watch what you are installing.
Some packages from Cydia will install other packages automatically to make a tweak work. There called "dependencies".
But not paying attention to what gets installed on your device can cause problems.
Pay attention.lol.![]()
