Ring tone
Status
Not open for further replies.
lizziejaneh
Created a ring tone and successfully synced it via iTunes.
Since I had to do a complete restore after a failed software update, I have synced my phone with iTunes, checking the tone, but on the phone I can't see the tone.
Why can I not see it, why does it appear not to be on the phone ?
In iTunes go to the tones tab and check that the sync tones option is checked. Check if the tone is checked if you have selected Sync only checked tones.
As this problem is solved i will close this thread, Thanks everyone.
Status
