nomoneydm
- Aug 4, 2011
I need to know what I should do in this situation:
I jailbroke my iphone 4 using jailbreakme.com and i didnt sync with itunes before hand because i didnt have a working computer. When I bought the iphone a few months ago I synced it with itunes before my computer took a crap. I have an option to restore from the backup i made then, or setup as new iphone.
Which if I am correct, if I setup as new iphone i will not have a stock backup. what should i do?>
thanks in advance
p.s. I hope this is in the correct section of the forum..
Thanks
Josh
thanks in advance
Thanks
Josh
