picture size help.??
1iwilly
is there a way to resize the picture you take with the iphone 4s before sending it. like to 640x480 for some reason my wifes old phone won't let her see the pictures i send her
if the size is higher i guess.???
ok i found this=you can change the picture size for multimedia messages (MMS) in the settings of your iPhone.
Under "General", "Network", "Cellular Data Network" and "MMS Max Message Size" you can set the picture size.
Please notice: usually your network operator is responsible for this settings and can change every multimedia messege for work with every phone in their network. ok i tried it and it works tmobile had it set to 1048756 i change it to 640480 hope it helps others
