Need help transferring music to 5c.
MARQEVANS
I have my music on my hp laptop running windows vista. it is stored in iTunes. None of it purchased from iTunes. It currently syncs with my iPod Nano. If I hook my 5c up to my computer via USB, can I transfer the music t the 5c?
Gregoris
Administrator
United Kingdom
Just do the same as you would with your ipod and you can transfer all the same music, just check the music tab and make sure its all set to sync and it will do just that
willerz2
Super Moderator
New York
See if authorizing the computer for use with your 5C corrects this.
OP
M
MARQEVANS
Thanks worked like a charm now all the music is on the 5c. Hope it still syncs with the iPod too!
jimmy147
No, you should import your music into iTunes and then sync with your iPhone 5C.
Here's the steps: Download iTunes > Add music > Connect your iPhone > Click in iTunes on your iPhone > Tab music > Check music you want > Sync.
Well, if you wanna transfer videos to your iPhone, click here to know the detail tutorial.
jimmy147
No, you should import your music into iTunes and then sync with your iPhone 5C.<br>Here's the steps:&nbsp;<span style="color: rgb(51, 51, 51); font-family: 'Lucida Grande', 'Lucida Sans Unicode', Helvetica, Arial, Verdana, sans-serif;">Download iTunes &gt; Add music &gt;&nbsp; Connect your iPhone &gt; Click in iTunes on your iPhone &gt; Tab music &gt; Check music you want &gt; Sync.</span><br>
Most reactions
