- Oct 9, 2014
Hi,
Thanks for checking out my post.
So here's the deal. I have an iPhone 4s that I want to sell on eBay now that I have the iPhone 6. The iPhone 4s is jailbroken. Normally in the past, I would simply plug the iPhone into iTunes and RESTORE the iPhone to factory settings. Easy and fast, and no evidence that the iPhone had been jailbroken.
However, in this situation, it is well known that the iPhone 4s should NOT be updated to the iOS 8 operating system because the processor on the 4s isn't powerful enough to handle such a task intensive OS. So I cannot simply do a RESTORE function in iTunes becauses it will automatically update the 4s to iOS 8. I talked to Apple tech support and was told there was no way around it being upgraded to the newer operating system if I used the RESTORE function.
I then googled how to remove Cydia from the iPhone and wikihow stated that I had to first go into Cydia and remove all the apps that I had installed through Cydia. Fortunately I only had about 10 apps, so it didn't take long. But then it went on to say that I need to go into RECOVERY mode and after that plug it into iTunes which I know would be a disaster.
Moreover, I tried to delete the Cydia Installer, but it gives a warning messages that is scary. It says, "...the removal of one or more packages that r required for the continued use of Cydia or iOS. If u continue, u may not be able to use Cydia to repair any damage."
I also tried earlier on to go through Settings -> General -> Reset -> Erase All Settings and Content. Amazingly, this had no effect whatsoever on iPhone. It never did finish its cycle because it would go into this endless spinning dial that last for an hour before I did a hard reset. Afterwards, when I powered ip the iPhone, it started up five and looked the same as always.
I cannot sell a 4s with a iOS 8 operating system because it is not fair to the buyer who might not know that the iOS 8 system would impact the iPhone's performance.
I have to believe that there is a way to wipe the iPhone clean of my data and apps and keep it from updating to the iOS 8 operating system. I would really appreciate if someone would tell me how to proceed. Thanks.
