Mute problem
Mute problem
Proner_0
Hi everyone, I have this problem when I switch the mute on my iPhone it still makes quiet noise. I Also noticed when I switch the mute switch back I see the bell symbol and that below it shows one block of volume. How do I fix this?
probably getting confused with ringer volume and device volume, only thing i can recommend is go to settings > sounds and set the toggle change with buttons to off then put the slider all the way up, that should make ringing louder and the volume will only control things like music/video.
I hate to break it to u but it's its own kind of volume I can tell becus of the bell symbol
