Looking for wireless wall charger
Kimrisa
So glad to have found this forum! Can someone recommend a cordless iphone 4 charger that plugs directly into the wall? I know there are some for the iphone 3g but I'm not sure what's compatible with the iphone 4.
Thanks!
Well at present this is not available here.
As soon as the product is launched it will be informed to you. Till than it will be better for using the same traditional version.
Scosche reviveLITE II Docking Home Charger for iPod and iPhone. Says it's compatible with Iphone 4....
