Lock screen tweek help
taylor4338
There's a lock screen tweek that looks like ur home screen but u slide one of ur icons to unlock it but it says it won't work with my iPhone 4 cause I'm running on 5.1.1 it says it only works with older versions. Does anyone know if there's one out there like that that will work for my device???
If cydia says its not compatible then I would trust that. Does the tweak you are talking about use an icon at any spot on the screen and you just press it to unlock? Or an icon were the slider used to be? Maybe wait and they might support your firmware in the future. If you are talking about the one that uses a icon image instead of the slider knob, you can ssh and remove all the slider images then replace the knob image with one resembling an icon. Then just use a homescreen screenshot for bg. should do the trick. There might be a method to do this using winterboard, but I personally don't use winterboard. Don't forget to back up the original files though.
