Iphone 6 Calendar small issue
dave307
Active Member
South Wales UK
Good day to all.
Using the calendar app on my iphone6 every day, Just one little annoying thing!
I go to set date time and enter the txt for the heading.
I scroll down to the Alerts section and sometimes I don’t need any alerts, So under the alerts tabs I select None and also select None for the second alerts.
I select Add. Job done.
For one reason I went to edit one item in the ios calendar and the item that I chose with no alerts but in the edit section it showed up Alert 15min, Which I don’t want.
Now every time I go and make an entry into the calendar I have to double check in the edit section that the alerts are set to None.
Is there a way around this or is it me or is it the norm for the ios 10.3 calendar.:confused:
Many Thanks David.
Brilliant. Many thanks for that. It's been bugging me for a while.
I was going to add to my question another calendar point. Can I change the setting at the bottom from Busy to Free as default.
Many thanks once again and your speedy replies.
David.:)
