Iphone 5 screen problem
spinningking
Hi all, the problem I am having is, the start screen magnifies too a huge size and the only way I can get it back to normal is to reset the phone. anybody else have this problem? Thanks, :)
This is a feature that will magnify the screen if you hit the home button 3 times in a row. Next time it happens try hitting the home button 3 times and see if that takes it back to normal. You can try hitting it 3 times now and see if it magnifies the screen. If so you change that feature.
You can also just turn off that feature in settings.
