Then I'll either wait or see what offerings appear in Android. The Droid Prime looks like it's going to be nice.
On paper yes. In real world use, that is a different story.
Until Google deals with the core issues that are causing most of the complaints about Android, it will always be a second rate OS.
Lets list off the biggest issues.
7 screen resolutions. That alone makes apps look like crude across a lot of devices.
4 GPU setups. Most of the big game developers won't touch android because they don't know what kind of speed they will be dealing with for framerate.
4 memory configurations. Again big developers want to know how much memory they are going to have access to.
13 versions of the API. Granted only the last 5 are now in use for 90% of the market, but that still is causing major issues with deployment.
Dalvik Virtual Machine. Until enough apps switch to the NDK, the issues here are too numerous to list.
Divided market place. The user has to remember WHERE they bought each app now. And it is possible to end up buying it twice from two different markets if they aren't careful.
Malware applications on the market place. Google has had to mass remove over a hundred apps now. Seriously, how many people even know they need to run a virus scanner on a phone?
Application permission system. Google really hosed this up beyond belief. They expect users to understand the implications of each permission the app is requesting on install.
Run away multitasking. How many apps truly need to be loaded at once doing something?
Run away hooking to events. Ebay's app hooks to "On connection change". Which forces the app to load every time you switch from WiFi to 3G.
Yeah, Android is a REAL winner of an OS for phones.
