iPhone 4S Theming Problem
winkillerx
Canada
Is more to do with, "infinifolders"
Recently (Don't know what happened) every time I click on one of my inifinifolders, the background image that is in the app selector, is smaller and shows the background of my theme.
I know you can either go to these 2 locations in ifile:
Bundles\com.apple.springboard
or
System/Library/CoreServices/SprinBoard.app
now these files contain the image for the background and the dimensions are 640 x 960
FEFOLDERBG@2xpng, FolderSwitcherBG.png, FolderSwitcherBG@2x.png, FoldersWitcherBG@2x~iphone.png
Heres a screenshot:
Springboard:
Heres my problem, with infinifolder background:
See how the background image is smaller. Can someone show me how to fix this?
Thanks,
X
Perhaps It is a bug with Infinifolders
I'm not sure...I quit using that tweak.
Perhaps try the FolderEnhancer tweak.
It does what Infinifolders does...except more...and makes using folders a much more pleasant experience.
I don't know that FolderEnhancer gives you "unlimited" folder space...but I know that you can fit up to at least 3 pages of apps within each folder.
Maybe even more. Either way....I'm sure you will "not" run out of room inside a folder for all your apps.
Folder enhancer works and seems to be alot better that Inifinifolders, thx Zig!
