iOS 10.2 beta 4 battery drainage very high
prithvi64
after waiting for more than a week, we were delighted to install 10.2 beta 4 yesterday but using it more almost 2 days, battery drainage is much higher than beta 3. Even I would say, it is highest among all builds so far. No doubt, beta 4 has solved Health app refreshing issue and lags. I am using iphone 7, whether users of iphone 6s and 7+ are also facing similar battery drainage?
I've only installed it one day but so far didn't notice any battery drain or difference from previous beta on my. iPhone 7 plus
I'm currently running iOS 10.2 Developer Beta 4 and haven't seen any unusually high battery drain. Have you checked in Settings>Battery to see what is using your battery power?
I didn't notice a difference in battery usage, compared to Public Beta 3, so far.
Did you reboot your iPhone after the update?
