How is iTUNES 10.5 beta running?
bodean
People finding it stable and an improvement over the latest official release?
stick with the official release, there is no real reason to use the beta itunes apart from being able to sync ios 5 beta 7
i still use the 10.3.it is ok .i do not find the different with the before version……
The version of iTunes that comes with beta 2 cannot sync devices that have the beta 1 software installed. To avoid this problem, do the following:
  • Sync any devices that have beta 1 installed to the version of iTunes that came with beta 1.
  • Upgrade iTunes to the version that comes with beta 2.
  • Connect the device and install the beta 2 software. (Understand that you might see a failure to sync error when you first connect the device.)
  • After installing the beta 2 software, restore from your the backup you made in step 1.
