Okay I found the solution. Do you have androidlockxt? If you do you, then go on the lockscreen with the grass (the endroid one) and click the home button..or hold the power button. The androidlockxt comes up and you have to do your pattern..from there it works because then it unlocks.
i am having a problem too. i understand that i have to click the home button again and swipe to unlock like on the regular springboard but how do i get rid of the normal unlock and use the dreamboard theme's unlock function??
I have a problem of the dreamboard lockscreen...how can i rid the default ios lockscreen and use the dreamboard lockscreen? Pls help me to fix this problem... Tnx
