Bigger system fonts
Bigger system fonts
Thegrillboy
Is there a way to make the system fonts a bit bigger ? I have bytafont installed but I can't make fonts bigger
I use and like the tweak Shrink ($1.49, USD). It's for the font size (only) on the springboard and not only can you enlarge/reduce the size (and color) of your springboard font, but you can also change the size of your icons and badges, also.
Hope this helps.
Marilyn
Thank you works good. Anyway to make page rendering double zoom like androids? My eyes are getting pretty bad.
Hi i have something that might be able to help you out if you can see the screen properly......
It's a cydia tweak called Springtomize i have made a very quick video of what it looks like and the setting to use...... (Not the best video ever at all lol)
(The break in the video at 0.58 is where you should click reload at the top of springtomize and respring but if i do that the video doesn't save lol)
And here are some pictures of the affects.
Before:
After:
Hope this helps you out.
iNeoTom
