Battery only charges to 93%
CXXXV
No matter how long I leave the phone on charge all it ever shows is a max of 93%?
No I won't update until all the votes are counted. So far the feedback is not good.
Let it drain all the way down until it shuts off on its own. That should happen at 1%. Charge it all the way back up. If this is not part of your normal routine, it wouldn't hurt to do it again. Apple says that a full discharge/charge ought to be done once a month.
I always do that. I've done is at least 5 times since receiving the phone.
Hmmm....don't know what to tell you then. Are you a "power user?" Has your battery seen a lot of heavy use? Is it possible that it's time for a new one? They do have a limited number of charge/discharge cycles. You posted in the New Members forum so I don't have any idea what model you have or how long you've had it.
