Battery Case
Discussion in 'iPhone 4' started by drivembig, Oct 1, 2012.
Thread Status:
Not open for further replies.
  1. drivembig
    drivembig New Member
    Oct 1, 2012
    2
    Hello all, I am looking for a case for my Iphone 4 and came across a case with a 1900MAH battery in it. The case plugs into the Iphone and has an on and off switch. When you need battery just turn it on. It comes with a USB to recharge it. Looks pretty cool. Does anyone have any input on how well these things work? Thanks in advance.
  2. Horsehaulin
    Horsehaulin Member
    Feb 6, 2012
    578
    24
    18
    Fort Wayne, IN
    What brand and model? This info will garner you the reviews/opinions you are looking for.
  3. Bula
    Bula New Member
    Aug 5, 2012
    556
    37
    I'm using a generic non branded battery case straight from a major Chinese Electronic site....works well..it was cheap...mainly use on holidays...
  4. drivembig
    Oct 1, 2012
    2
    The case that I am looking at is here
    1900mAh black iphone4 & 4s USB charging external battery case brand new | eBayhanks for any opinion....
  5. Bula
    Bula New Member
    Aug 5, 2012
    556
    37
  6. carmin
    carmin New Member
    Jan 14, 2016
    6
    3
    There is a battery case with 3500mAh can be recommended for you, it can be vertical stand and with SIM card stock box, and with 4 LED indicator on its back,stylish design also. I just bought it from amazon a month ago and feel it was an amazing case for my iphone6. oopps,I just found that you are searching case for iphone4/s. Sorry.
  7. bear7962
    bear7962 Well-Known Member
    Feb 8, 2013
    1,771
    1,024
    113
    And they were having this discussion more than 4 years ago. I am guessing they are long gone.
  8. scifan57
    scifan57 Super Moderator Staff Member
    Sep 24, 2012
    23,998
    20,528
    113
    Regina, Canada
    Since this thread is over 3 years old and the OP has not been back since then, this thread is now closed to further replies.
    • Like Like x 1
Thread Status:
Share This Page
