A Signal Speed Boosting Case that Works!
Chromatic
I've used many of the passive boosters over the years,.. all of them were mostly "snake oil" -- didn't work.
However, I gambled again with the ReachCase R79X Case, and not only did it work,.. it Improved 4G/LTE Download speeds, and Doubled my upload speeds from 10Mbps to 20Mbps.
Every review, video, etc I've read or watched has not tested the case in the way I did (not to say someone else hasn't ) -- Which was to take two 100% identical Iphone 64GB 6S's on the Verizon Network,.. Place them in field test mode,.. Put them on a table side by side,.. One one of them I put them Signal Boosting case, on the other I left it without any case to rule out all variables I could.
If interested in the results - I made a video showing the signal increase,.. and ran a plethora of speed tests which all definitively showed/proved this case works. (I may be the "ideal" candidate with 1-2 dots/ -100 to -115dB signal) But either way, the video results are hard to deny:
To see the video click this image - below:
Anyone else use this case? Does/did it work for you?
