hi, ive got same problems aswell, phone did freeze a bit before installing ios5 like you say turns off , attempt to dial a number and end call but it wont, sent off to apple via o2 shop and got this reply-
| Estimated Cost: | |
| Grand Total: | £119.00 |
| Action Required: | |
[TD="class: label, colspan: 2"]Thank you for sending your Mobile Phone to us for Repair. Unfortunately your handset is not covered under the manufacturer’s warranty so we have raised the following estimate for you: [/TD]
[TD="colspan: 2"]Your handset has been assessed by one of our Apple engineers and to perform a repair, this handset requires a new Housing Case. The price quoted is fully inclusive of a full repair and installation of the latest version of manufacturer software. [/TD]
[TD="colspan: 2"]This is a fixed price estimate based upon a pre-repair assessment of your handset. [/TD]
[TD="colspan: 2"]
The job may be subject to re-estimate if other components are found to be faulty, or if the product is not on our current supported list.
[/TD]
[TD="colspan: 2"]The following options are available: [/TD]
[TD="colspan: 2"]1) Accept the estimate. [/TD]
[TD="colspan: 2"]2) Refuse the estimate and authorize the destruction of the handset free of charge. [/TD]
[TD="colspan: 2"]3) Refuse the estimate and request the return of the product.
by the sounds of it they havnt even opened it up yet to check it out but are saying the case is nackerd. its got a deepish scratch on the top right hand corner,
i have warranty on it til 04/01/2012 but not fot the case apperently.
simon.[/TD]
