3G not activating need help
Amc0520
Hi everyone... Got an iphone 4 for almost 3 months now..
I got no problem with wifi access or edge but i cant seem to activate my 3G
I did try to off and on my phone and also the enable 3g off and on
But it didnt work
I did turn on and off the airplane mode and it seem to restore the 3g but after a few minutes it went back to edge
I got no problem with this on my first month after buying the phone
Also i reset my network settings still able to get the 3g but only
temporarily and it went back to edge
I need your advise about this and maybe can help on what to do
You need to report the issue to your service provider. If you are jailbroken I would ensure the jailbreak is not causing the issue by removing it.
I will certainly go check with my carrier... Its not jailbroken...
Its just annoying since i dont have wifi area near my place and edge is so slow...
The 3g activated earlier and now im back to edge as in typing this
