Wireless charging
Wireless charging
Smurf2612
Is an Apple wireless charger compatible with an iPhone 8?
Yes. Our iPhone 8s both use wireless charging, but take care with positioning on the charging pad. It is easy, I find, to miss the hot spot, although there is a ‘boing’ to tell you that it is charging. The other point to bear in mind is the thickness of a phone case, if you use one, which increases the separation between phone and charging pad.
If you use a MagSafe case it will perfectly position the wireless charging puck for fastest charging.
