Use mobile data for.. settings problem..
IHulk
Hi,
Not sure if anyone else has this problem.
Even if I turn all data switches off the switches change back to show on and I have to restart the phone every time I want to change them..
Thanks in advance
Perform a hard reset by holding both the power and home button and releasing them both once you see an Apple logo on your screen
Sent from my iPhone via Tapa
Thanks for the reply,
I have tried that and it's still the same, I've also tried resetting all settings and it's still acting weird..
I might try a full phone reset in the next few days.
It only started doing it 1 week ago, really baffled...
Little update...
It seems to be all the ones I turned off originally that are showing as on, but they are in fact off until I restart the phone.. They can not be changed..
*confused*
Hey, done a full wipe and reset, now it says cellular and only has 2 apps available to change...
I give up! :/
Try restoring again, but this time, set the device as new rather than restoring from a backup, and see if the use data toggles are working. If they are, then it's an issue with your old setting preferences in your backup. If it is the case, there's a fairly easy solution.
Sent from my iPad Mini via Tapa
Thanks Willerz! :)
That fixed it, I binned the backup and am starting again.
