SBSettings install problem-libactivator package
enlightened
NYC
Getting this error message when trying to install SBSettings:
"I wasn't able to locate file for the libactivator package. This might mean you need to manually fix this package."
What does this mean/ how do I fix it?
Thanks!
This happened to me also just today, a
Dfu restore and a fresh jailbreak will fix it :)
Thanks. Not sure exactly how it worked but I installed Activator and then the other apps that said they needed libactivator started to install when I clicked on them. I guess Activator must include libactivator?
Going to hold on to that link in case anything else happens again. Thanks!
Apparently it is enough if you reset your network settings. It worked for me:
Activator "is" libactivator. They are virtually the same exact package. They are not 2 different packages.
