Need help removing lock screen theme (hiro)
mach1man
Ok so I'm going through the Hiro theme trying to remove all of the brown banners. I've gotten most of them, the one I can't find is the lock screen. Where is the lock screen bundle so I can remove the brown banners.
Can you specifically state which brown banner you mean? There are a lot that are/can be on the lockscreen. Even if you take a screenshot of the one you mean will help. Thanks.
Marilyn
Those brown banners lol
Look in your theme for a folder titled "TelephoneUI." That's where those bars should be found. You'll be looking for images called "bottombar[something]." That's where I would start looking.
You could also get a clear lockscreen Winterboard theme and either look through it for the images or put it on top of the theme you're trying to alter.
Hope some of this helps.
Marilyn
That was it!! I deleted that folder and now I'm good. I'm starting to get the hang of this a lil more each day thanks to all of you!!!!
