iphone 8 help downloading
Discussion in 'iPhone 8' started by mike1, Dec 26, 2018.
  1. mike1
    mike1 Member
    Oct 5, 2011
    92
    4
    8
    OK it seems I made the mistake of recording Christmas morning in 4K 60 fps. Now I'm accustomed to recording 2-3 minute videos, and transferring to my PC with no problems. But this video is about 35 minutes long and can't seem to complete the process without an error message saying "something went wrong. (after 2 hours downloading). My son even tried transferring to a cloud program and that didn't' work either. What can I do to save the video? Thanks.
  2. NSquirrel
    NSquirrel Active Member
    Mar 23, 2017
    117
    156
    43
    UK
    Which app did you use to record it? If you recorded via the photo app, then using a PC or windows to access icloud photos may help.
  3. mike1
    mike1 Member
    Oct 5, 2011
    92
    4
    8
    Which app? Not sure what you mean. I used the iphone camera.
  4. NSquirrel
    Mar 23, 2017
    117
    156
    43
    UK
    Thanks Mike1 as there are lots of camera/ video apps, which save things within the app. So I would think the video should be on icloud photos and to get to it you may need to go via a PC or Mac; possibly iTunes, but I am not sure about that.
    Another way maybe via an app like FileBrowser on your iphone, which I use to move photo and files, etc. between my iphone and iPad and networked storage.
    I hope this helps you.
    • Like Like x 2
  5. NSquirrel
    Mar 23, 2017
    117
    156
    43
    UK
    Just thinking... I assumed that your photos are backed up automatically to icloud and I hence assumed that the phone has copied the video to icloud photos.
    If not, then go to FileBrowser, which is really useful to have installed anyway. (I forget whether it is free or requires a small payment to install. Just checked and it has a 14 day free trial.)
    • Like Like x 2
  6. mike1
    mike1 Member
    Oct 5, 2011
    92
    4
    8
    OK thanks, I'll try filebrowser. I'm assuming this will handle a massive file like this one?
Share This Page
