iphone 4S - speaker and microphone works.. but NOT when in calls..?
Discussion in 'iPhone 4 FAQ' started by Adamw1109, Feb 15, 2014.
  1. Adamw1109
    Adamw1109 New Member
    Feb 15, 2014
    3
    I have bought an iphone 4s..
    My music plays, games plays audio, my audio and mic works fine on Skype, my siri works fine..
    BUT when I call someone or someone calls me I cant hear them or they cant hear me?
  2. Ledsteplin
    Ledsteplin Well-Known Member
    Oct 23, 2013
    2,705
    4,413
    113
    Florence, AL
    You said you can't hear them OR they can't hear you. Is it one OR the other, or does no one hear at all on both ends?
  3. Adamw1109
    Feb 15, 2014
    3
    No one hears at all on both ends..
    But its only in calls.
    In any other game or app such as skype, the sound and mic works fine
  4. Ledsteplin
    Oct 23, 2013
    2,705
    4,413
    113
    Florence, AL
    Have you tried resetting network settings? Settings>General>reset>Reset Network Settings You will need to add your wifi passcode back in afterward. Not sure if it will work, but worth a try.
  5. zstairlessone
    zstairlessone Well-Known Member
    Feb 12, 2012
    2,475
    3,991
    113
    A friend had the same problem, them hearing him only, on his 4 and it turned out to be the second mic was bad. He was still under AppleCare and had his phone replaced.
  6. Adamw1109
    Feb 15, 2014
    3
    yeah tried that.. no difference at all unfortunately
  7. bear7962
    bear7962 Well-Known Member
    Feb 8, 2013
    1,693
    923
    113
    Did you check the proximity sensor? If it is not working correctly (and some cases cause a problem) your cheek will put the phone on mute.
  8. NightWoFt
    NightWoFt New Member
    Feb 19, 2014
    I having this problem before. After that I change the plug in ribbon [​IMG]then working.
Share This Page
