ok, thanks for all your help you've been brilliant, if people ask what network it was on origionally what should i tell them?
also make sure that you indicate that it has 4.0.1 software it's worth more that way )).
nothing. it should matter anymore b/c it's UNLOCKED. Tell them you can use any carrier.
it does matter because when that person goes to upgrade or restore they will be screwed. its always better to be honest and up front and say it was unlocked using jailbreak/unlock tools
yes that is true, he needs to tell that it is Jailbroken and Unlocked, but who was the original carrier IT DOESNT MATTER! b/c even if you tell them that it was O2 or whatever they can still accidentally UPGRADE TO 4.1
i have been asked if 'jailbreak' interferes with mms and facetime!!!! apparently some girl says she has read that it does, any idea?
that limerain trick was slick though. I didn't know you could use it to activate the phone without the sim card. Will it work on nay version?
yep and greenpois0n does the same it hacktivates it. though for me i dont need activation. it would be nice to be able to turn it off, not that im gonna jailbreak lol
what do you mean, you dont need activation? and turn it off?
Apple iPhone 4 Black (16GB) Mobile Phone on eBay (end time 27-Oct-10 13:32:13 BST)
Hi chaps, if you have time! Do you think all information provided is ok? Thanks
