Armband help :)
Are you planning on running off road or distance ??
If you are, then also consider the camel bak hydration vests. Essential for any distance, pockets for everything and your phone, and water in a 1.5lt bladder
I use the camel bak bum bag, but I'm considering upgrading to an ultra vest as it distributes the weight nicely
Also, runmeter is an amazing running program, I have spoken to the developers and was shocked at how helpful they are, the base app is now free too ...
Good Luck with your running
