4S Battery Self Discharge?
Discussion in 'iPhone 4S' started by KenithO, Mar 13, 2018 at 10:53 AM.
  1. KenithO
    KenithO New Member
    Mar 10, 2018
    As mentioned in previous post, I recently inherited a 4S that has not been used for a while.
    Am concerned about the battery so have been searching for info on normal 4S battery self discharge.
    Did 4S forum search using keywords 4s battery discharge and got 11 results none of what I wanted so Googled using keywords "iPhone 4S" battery self discharge got ~ 40.4K results.
    Of the top ones checked "What is the battery life of the iPhone 4S in "real-world" tests? Is the battery designed to be replaced?" iPhone 4S Battery Life (Real-World Tests): EveryiPhone.com seems the most relevant concerning Standby Time which is listed as 200 hrs..
    Also checked the links and found "It’s worth noting that Apple has dropped the promised standby time from 300 hours on the iPhone 4 down to 200 hours on the iPhone 4S" Reviews: Apple iPhone 4S (16GB/32GB/64GB)
    While there is more work use at Apple iPhone 4S: Thoroughly Reviewed did not find any Standby Time tests.
    Has anyone been running Standby Time tests for their 4S?
    Was also looking for real discharge curves for the 4S battery but to date have found none.
Share This Page
